Test-Research-Inc.
Test Research, Inc.
November 14, 2011 - Updated
November 14, 2011 - Originally Posted
Electroplating Over Solder Joints
We have a need to electroplate a nickel passivationlayer over soldered joints. Do you know which type of solder would havebetter electroplating properties? 60/40? 63/37? Pure tin?
J. H.
I would go withpure tin as it would be the most conductive and also cut out the risk of issueswith different plating thickness on tin versus lead, the solder joint is a mixof metals so areas will be tin or lead rich. How ever I have to ask why wouldyou nickel plate over a solder joint?
Richard Boyle
Global Product Champion
Henkel Electronics
