Sponsor |
Ask the Experts |
October 31, 2011 - Updated
October 31, 2011 - Originally Posted
CEM1 Laminate Issues
We use CEM1 laminate. The laminate bubbles and de-laminates during the reflow process. Is CEM1 laminate designed for the higher temperatures of lead free solder?
The boards are stored sealed with a desiccant inside the package. We have tried pre-baking the boards for a couple of hours at 100 degrees C, but don't see much improvement. I know this could be cured by changing to FR4, but the cost is a concern. Is there a solution?
A. N.
Expert Panel Responses |
CEM1 is a paper-core material laminated with a thin layer of fiberglass. It is not usually able to withstand higher reflow temperatures associated with lead-free solder processing, in fact, it is even problematic for 63/37 solder processing and is typically only used for single-layer PWBs.
I sure wish I could provide some good news. If I knew more about the CCA, I could possibly provide you with alternative processing ideas.
Richard D. Stadem
Advanced Engineer/Scientist
General Dynamics
Sponsor |
