Yes, there are aqueous and solvent based cleaning agents that are designed for use in ultrasonic equipment and cleaning both, leaded and lead-free pastes.
However, any recommendation for the right cleaning agent technology depends on the paste brand and i.d. # as well as any sensitive materials used on the board's surface, which need to be considered from a material compatibility standpoint.
We suggest that you contactZESTRON's engineering department to review your process details and make a firm recommendation.
Umut Tosun
Zestron America
I am assuming you are using an aqueous solution in the ultrasonic cleaner right now and have a DI water source? Remember even though the focus is on the wash step you are only as clean as your last rinse.
There are several safe and effective solutions available to use in the ultrasonic tool. I can provide you with an aqueous concentrate that will require dilution to @10-20%. The next option is a semi-aqueous solution. This is designed to run at 100% (neat) strength.
Deciding on the right one will require a brief one on one consult with you. I would like to know the flux and/or solder paste you are using and ask a few more questions in regards to the potential for compatibility issues, etc. Please contact me for further information.
Charlie Pitarys
Kyzen Corporation
