Plasma Etch
August 29, 2011 - Updated
August 28, 2011 - Originally Posted
Fumes from Baking
We are purchasing an industrial oven for PCB baking prior to rework. Are there any health-related issues regarding exposure to fumes generated during the baking process? Should the oven be vented to the outside?
R. G.
An oven used to demoisturize the boards would typically operate in the 250 F temperature range. Some nonmetallic materials will off-gas at that temperature, but it will not be high enough to "melt lead". More than likely, a local code will require ventilation of the oven at a minimal flow rate of 50 CFM. If it were my oven, I would ventilate it. This will also reduce the chance of condensation of the off-gassed products on the cooler parts of the oven, such as a window.
Rick Perkins
Chem Logic
Best practice would be to have the oven vented to a scrubber or to the outside. There can be residual solvents, flux residues etc. present on a board (especially once it has gone through some assembly processes) that can be potentially harmful and/ or irritating when exposed to heat.
Kevin Beattie
Quality Manager
Sunstone Circuits
Kevin is part of the Sunstone Management team. In his role as Quality Assurance Manager, Beattieā€™s 25+ year background in Printed Circuit Board manufacturing is a tremendous asset to the Sunstone team. In addition, he brings valuable experience from his previous roles in the following areas: process engineering, new process introductions, support of nearly every manufacturing process, and extensive knowledge of Continuous Improvement, ISO, IPC, and various other industry requirements.
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
