August 7, 2018 - Updated
April 25, 2011 - Originally Posted
Delay Before Washing Water Soluble Flux
We are assembling circuit boards using a water soluble flux, but have run out of some parts. Is it acceptable to leave these partial assemblies for 3-4 days, then put the rest of the parts, and then finally wash them?
J. C.
Water-soluble fluxes have high percentage of organic activators and are generally corrosive in nature. For this reason, it's always recommended to clean these fluxes immediately. If not, there is always the risk of acidic activators etching the solder joints that could result in corrosion and electrochemical migration. In order to avoid any failures, it's always recommended to clean these OA fluxes as soon as possible preferably within 1 hour of soldering. In your case, we have ensure the fluxes are removed completely. Once you have the remaining parts, perhaps you might need to re-clean the boards. If you prefer to leave the partial assemblies having fluxes for 3-4 days, there is a high likelihood that you might need aggressive wash process settings and/or even making use of low concentration chemistry that would assist in successfully removing the residues under low stand-off components.
Umut Tosun
Zestron America
This is a difficult question to answer, without knowing the chemical makeup of the flux. Oxidation-reduction and/or acid/base chemistry can occur at room temperature over long periods of time. These events occur very quickly at higher temperatures which result in cleaning the metal oxides from the metallic surfaces. One of the questions I would ask is "does the desired cleaning/wetting effect occur at room temperature by the same path as it does at higher temperatures, or is the 'colder' but longer chemistry different (presumably with different results)? The reason for the vague answer is that all too often we see differences between results from accelerated test results compared to those from longer term test results, for any number of phenomena. At higher temperatures, chemical pathways can oftentimes be different than at lower temperatures. Other effects which may influence the long term result will be the effects of solvents (within the flux) on the board/component materials. Will long term exposure of board or component surfaces in contact with high boiling solvents change anything? I don't know. These would be my immediate concerns/questions.
Jim Williams
Chairman
Polyonics, Inc.
The residues from most water soluble fluxes should be removed as promptly as possible since they may begin to cause surface corrosion. This is very dependant on the supplier and type and I would recommend you contact your supplier on the subject. If I had to make a decision I would wash these with shortages and then re-wash when the assemblies are complete.
Bryan Kerr
Principal Engineer - CMA Lab
BAE Systems
This depends on the type of water soluble flux that you used. If you are talking about a wave solder flux then I would think that you would be OK assuming you are using a neutral pH flux. If you are using an acidic based flux then I wouldn't recommend it. Check with the manufacturer of the flux. As for solder paste that is water soluble, I know that FCT Assemblies do not have an issue with cleanliness after delayed rinsing for this time period.
Mike Scimeca
FCT Assembly
Not all water soluble fluxes are equally safe when left in place for extended periods before cleaning. You should contact your solder paste supplier to find out what the limits are for your solder paste.
John Vivari
Nordson EFD
The answer is really about what type of Water Soluble Flux you are using. Some that are not H1 or H0 activated will be fine to leave on the Boards. But those which are H1 or H0 activated according to Jstd004 I would recommend to clean them between soldering.
Greg York
Technical Sales Manager
BLT Circuit Services Ltd
A common answer in this industry, "...it depends". There has already been several fine reasons submitted for or against this practice of when to wash. Over my 29 + years in this industry I have seen too many horror stories associated with miss-application of OA fluxes. Details are thin as to the exact type of your water soluble flux so if I was in your position I would wash them as soon as recommended by the flux manufacturer. Washing your boards twice will be less painful then having to confront the potential of corrosion or some other issue that may arise once the board gets in the field.
Charlie Pitarys
Kyzen Corporation
