March 30, 2011 - Updated March 28, 2011 - Originally Posted Ideal Relative Humidity for Final AssemblyWhat is the ideal level of humidity RH% for a manufacturing plant? Our facility is used only for final assembly. We don't assemble/solder pcb's, but our finished products do contain many assembled pcb's. What is the ideal relative humidity for this type of final assembly facility? T. P. |
There are two scenarios to consider here. Low humidity will make the risk of ESD damage greater and you should therefore keep it above 30% RH. High humidity can result in a greater risk of corrosion or moisture absorption by components and PEC's therefore try and keep it below 65 % RH.
Like most things it is a compromise. Higher humidity increases corrosion (oxidation) and reduces static. Low humidity reduces corrosion, but increases static. The general consensus is 50-60% is ideal for most types of manufacturing.
