March 9, 2011 - Updated
March 7, 2011 - Originally Posted
Solder Paste Volume for BGA Rework
When we rework BGA components we typically apply solder paste. Our BGA rework stencils match the aperture size and thickness as used on our production line. Therefore the solder volume added during BGA rework is equal to the solder volume used during production.
Since rework can never be as controlled or consistent as original assembly, should we use slightly more paste during BGA rework to compensate for irregularities in board flatness, pad condition etc.?
M. B.
It depends on the technique employed for the rework. If you are dispensing, or printing, so the volume constraints will change. When rework takes place, the quality of the pad surface finish is key as highlighted. During reflow, the substrate pad material will dissolve partially into the bulk solder, so when rework takes place, the likelihood is that the surface material to bond onto will be more challenging - as it may be harder solution to solder onto. This factor is key successful rework. Rework onto copper is easier than NiAu surface for example - as typically Au will dissolve fast in the original reflow, and for the rework, Ni will be the surface. Another solution, instead of printing, or dispensing, is actually dipping the component into solder paste to ensure that the component has paste on all contact points prior to placement. Board flatness - if there is warpage on the board, the significance will show up not only on paste replenishment, but on accuracy of component placement. Certainly the warpage shape will play a part in determining the solution, but minor on substrate side - it is more challenging if you are putting down the same component. A smiley face warpage on the board will give challenge of bridging, and the sad face will give challenge of paste starvation. Target the worst case scenario - but if you can avoid the same component in the rework, that is best solution.
Doug Dixon
Marketing
360-Biz
