Plasma Etch
February 16, 2011 - Updated
February 14, 2011 - Originally Posted
SMT Adhesive Turning Black
Sometimes our SMT adhesive will turn a black color during storage. We store the adhesive between 5-10 degrees C. What could be the cause of this discoloration, and could it be impacting the adhesive properties?
M. T.
I need a little more info before I can help. What is the adhesive? Who makes it? I can't answer without knowing a little more. However, the adhesive properties can be evaluated against a control, "known to be good" sample of the adhesive. I suggest using a combination of instruments, such as DSC and TGA, and FTIR to take a look at thermal characteristics of "good" vs "suspect". I can be more specific if I know more about the adhesive itself.
Jim Williams
Chairman
Polyonics, Inc.
Jim Williams
Chairman
Polyonics, Inc.
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
