July 26, 2018 - Updated September 26, 2010 - Originally Posted Cleaning Conformal Coated Boards After ReworkWe need to rework conformal coated circuit board assemblies. After the rework is completed, can we send the board through our aqueous DI wash system? Are there any concerns or risk? B. P. |
I agree with the response posted earlier by Ms. Jade Bridges at Electrolube, Ltd. In a follow up response I would like to add; My experience has shown if you are using acrylic conformal coatings then after your rework soldering step when using only water soluble fluxes care must be taken in a heated aqueous environment. Acrylic coatings strength is mostly as a barrier against environmental elements, dirt, dust, smoke and atmospheric humidity for example. However DI water alone at high wash temperatures combined with high wash pressures can impact the surface adhesion of acrylic and it may start flaking off. Surface degradation will be highly evident in areas where flux has wicked underneath the acrylic coating and any locations with pin-holes, scratches etc. as a result of time in the field and rough handling for example. These affected areas can show up away from the rework site. Polyurethane, silicon and lastly parylene conformal coating as being the most "bullet proof" will stand up well to heated DI water and even a wash process using aqueous based chemistry required for the removal of rosin and no-clean flux. If the rework requirement is only several boards a day for example, then setting up a simple "soak station" with an appropriate safe aqueous chemistry to remove all the coating first then followed up with the rework soldering and post cleaning is the best way to proceed. This practice is common with several military accounts I have managed. Please do not hesitate to contact me for further assistance in this matter.
If you are cleaning reworked boards where all the coating has been removed then it should not be an issue, however standard cleanliness checks after cleaning are still advised. If you are cleaning conformally coated boards where only a section of the coating has been removed then there may be an issue. It will depend on the cleaning chemistry you are using and whether it attacks the remaining coating or not. In addition, if you are using an aqueous based wash system then the water resistance of the coating is also important. If the coating is affected by immersion in water for short periods of time then it could affect the insulation resistance of the coating and overall protection level. In the latter case it may be best to speak to the coating manufacturer to determine the feasibility of cleaning the coated boards.
It really depends on the chemical formulation and the solubility of the coating material in water at specific wash temperature. If the conformal coating absorbs the moisture, this may cause reliability problems in the future. Client needs to make sure the coating is water insoluble and the coating on the reworked area is fully cured before it goes through the wash process.
There is no need to put a reworked conformaly coated PCB through an aqueous wash system after rework. In fact this may harm the board as conformal coatings are designed to protect from high humidity and not direct contact with water and potentially cleaning chemistries. To rework, remove the coating in a local area with the recommended stripper, rework the device, rinse the local area with the recommended rinse agent, re-coat the area with conformal coating.
I strongly agree with Chris Palin of Humiseal. There is no need to wash the entire board to clean a reworked area. Washing the entire board will potentially add additional problems. It very important that the reworked area be cleaned and rinsed thoroughly prior to recoating.
Rick Ramirez, Specialized Coating Services
