September 20, 2010 - Updated September 20, 2010 - Originally Posted Bottom Side Component AttachmentsWhat is an acceptable percentage of bottom side attachments for components with a solder tab on the bottom? We have had several issues with a sub-contractor and we heard it depends on whether it is used for a ground connection or heatsinking, which doesn't sound correct. Can you comment? D. R. |
This does kind of depend on the reason for the solder attach as suggested by your sub-contractor. For heatsinking you may need as large an area as possible to maximise the heat transfer whereas electrical continuity to ground may not be so critical. Personally I would try to satisfy both while including some tolerance for your production process and variation in component stand off etc. Aiming for a minimum of 50% solder coverage would seem to be a reasonable, achievable target however be aware that you are likely to get a level of voiding in such solder joints unless you are using a vacuum soldering process and you will have to decide whether the 75% includes or excludes any voiding. X-ray will be the only way to check it.
This question needs further clarification and possibly a few photos.
