September 15, 2010 - Updated September 13, 2010 - Originally Posted Ultrasonic Cleaning Solution RecommendationWhat cleaning solution would you recommend for cleaning electronic circuit boards using ultrasonic cleaners? What temperature setting would you recommend? D. D. |
Any water based or solvent based PCB cleaning agents could be used in your ultrasonic equipment depending on the brand / id number of the paste / flux you use and your process requirements. Is this going to be a post solder cleaning or pre-solder (misprint) cleaning? Please contact Zestron Corporation (phone: 703-393-9880) for cleaning agent and wash settings recommendation. We would gladly assist you. For water based cleaning agents, you could go up to as high as 160 degrees F as they are not flammable; however for solvent based cleaning agents, due to the fact that they might have a flash point, you need to operate either at room temperature or 20 degrees C below the product's flash point to be within a safe process window.
The cleaning solution chosen will depend on the residues you are trying to remove. There are many cleaning products available that would be suitable for ultrasonic application. The temperature that these should be used at to effectively remove the residues will depend on both the cleaning chemistry and the application. Your best option would be to discuss the details of your application with a materials supplier so that a suitable process can be developed. If you wish to discuss this further, please do not hesitate to contact me direct.
My recommendation would be any of a number of well-known, neutral-pH, aqueous-based cleaning fluids. MicroCare has one such product, called the Reflow Oven Cleaner (#MCC-ROC) and it, or many of its competitors, would be a good choice. There are a couple of factors you should keep in mind:
