September 9, 2010 - Updated September 7, 2010 - Originally Posted Abrupt Decrease in DI Water ResistivityAll of a sudden we noticed an abrupt decrease in the resistivity of our DI water cleaning system. There we no unusual changes in our process, or the products we routinely clean. Can you point us in a direction to investigate? E. V. |
If a solvent or water based cleaning agent is currently used in the wash process, those could be the reason. If there is an equipment failure, then there could be the cross contamination of the dragged out or evaporated chemistry with the rinse water that is normally going back to the treatment system. If only pure water is being used in the process, too much flux accumulation can also cross contaminate the rinse water and block the DI-water beds. We would need more information on the machine set up, cleaning media, and the type of flux used in this cleaning process. Please contact Zestron, so that our technical team could assist you.
An abrupt change as you described will be hard to nail down without more specifics on your wash process. The two major points to help me assist you are;
Without more info this is a hard one. I would immediately suspect either equipment malfunction (detectors) or more than likely, some trace contamination getting into the water supply. Any contact with aluminum, copper, or iron surfaces? I would also run an ion analysis of the water to try and pinpoint specific contributors to this problem.
