Plasma Etch
August 11, 2010 - Updated
August 9, 2010 - Originally Posted
Solder Mask Contributing To Solder Balls
Is there any relationship between the shape of the solder mask defined area around surface mount pads and the rate at which we see solder balls? Could increasing or decreasing this area effect solder ball formation?
F. D.
From my perspective as a chemist, the solder balls form when the surface tension of the solder mask will allow them to form. Also surface roughness may contribute to their formation by means of allowing a crack or crevice to initiate the formation.
Jim Williams
Chairman
Polyonics, Inc.
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
