Plasma Etch
July 28, 2010 - Updated
July 26, 2010 - Originally Posted
Soldermask Insulation Issue
We have an unusual component situation. A long lead on an SMT component is overhanging the pad. Can solder mask in this area provide an acceptable level of insulation between the overhanging component lead and a circuit conductor running below?
F. A.
No. Solder masks are not designed as dielectric insulators.
Dr. Craig D. Hillman
CEO & Managing Partner
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
