July 21, 2010 - Updated July 19, 2010 - Originally Posted Gold Plated Lead DiscolorationWe have a component with gold-plated leads that are turning purple after going through a lead-free nitrogen reflow environment. We are using a no-clean lead-free solder paste. Simulation done by applying solder paste on a certain part of the leads showed similar discoloration after reflow. Why are we seeing this discoloration and what is the most likely cause? C. T. |
Can the discoloration be removed by cleaning with a solvent (such as acetone), i.e. dip a 'Q-tip' in acetone and try to rub off the discolored area. Since gold is essentially chemically unreactive in ordinary environments, my suspicion is that the discoloration is coming from an as yet unknown source. For example, trace amounts of plasticizers can be leached out of plastic tubing when such tubing is used to transport nitrogen gases from tanks and connected to instruments or chambers. I need a little more information, but this kind of 'systems analysis' will disclose the problem. First, try to get a trace analysis as to the composition of the discoloration itself. An IR microscope may be the ideal instrument, especially if the discoloration cannot be readily cleaned off. After some thought, I have submitted this second answer. There has been much discussion lately that "no clean" is a misnomer. In fact, cleaning is generally still desireable ... In this case, a little more detective work (i.e. identify the composition of the discoloration) should provide the information needed to isolate the root cause and eliminate the problem. Also, how good is the gold plating? Trace amounts of other more active metals can result in strange chemical effects.
It appears gold (Au) from the leads is diffusing into the solder and forming a solder-gold intermetallic compound (IMC), which is indicated by the telltale purple color on the surface. According to published reports, a 3-5 wt. % of Au in solder can cause embrittlement of the solder, so you will probably want to look into adjusting your gold-coated leads, your solder material, and/or your reflow process (such as time, temperature, etc.) in order to minimize or eliminate this problem. Otherwise, you risk brittle failure of the soldered joints over time and temperature cycles. Here are a couple of articles on the Web that discuss Au (gold) IMCs: (1) Cambridge University Press (2) Gold Bulletin
Global Marketing Manager Nordson MARCH Mr. Szymanski works to expand strategic alliances, strengthen partnerships with equipment suppliers, and develop future product offerings tailored to the semiconductor market.
NOTE: Mr. Szymanski is no longer working at Nordson MARCH |
