June 16, 2010 - Updated
June 14, 2010 - Originally Posted
Advantages Using OSP Surface Finish
What are the advantages using OSP surface finish? What precautions should we take when using circuit boards supplied with OSP finish?
S. B.
The biggest advantage of an OSP finished board is the price. OSP boards tend to be cheaper than those fabricated with other surfaces such as HASL, Immersion Tin, Immersion Silver or ENIG. Another advantage that OSP has, particularly as compared to HASL finished boards, is the flatness of the pads. The primary drawbacks are related to solderability, shelf life, re-use of misprinted boards, and multiple heating cycles. The solderability/shelf life issues are connected; if the OSP degrades through shelf life (typically less than 1 year), the Copper underneath oxidizes fairly easily and prevents the board from being generally easy to solder. The re-use of misprinted boards can also be an issue with OSP since alcohol and other solvents used to clean misprinted boards will also remove the OSP, leaving the Copper surface very easy to oxidize. Misprinted boards that are cleaned need to be sent back through the print/place/reflow processes quickly to avoid this issue. Finally, OSP boards can be susceptible to solderability problems when subjected to multiple heating cycles; this occurs as a result of the OSP itself being degraded by the heating processes. There are new OSP materials that can overcome all of these issues, so consult your board suppliers to see what they can offer.
Brian Smith
DEK International
The big advantage with OSP as a surface finish is that it is coplanar unlike Hot Air Leveling. OSP is also relatively inexpensive when comparing to ENIG. The issue in the past with OSP was that the coating didn't hold up well to multiple heat cycles. Over the past 10 years or so we have seen an improvement in this area but I believe you still need to be careful with storage of your PCB's.
Mike Scimeca
FCT Assembly
Flatest surface for SMT placement. No possible contamination from Bareboard assembly chemicals interfering with long term reliability. Shelf life should ideally be twelve months from application but not all OSP's are the same so check manufacturers instructions
Greg York
Technical Sales Manager
BLT Circuit Services Ltd
