I would recommend the no-clean process. The problem with a water soluble process for QFN and DFN devices, is that cleaning underneath is very difficult due to their low standoff.
The residue from a water soluble process is corrosive, and, if not completely removed, can cause a variety of defects and, ultimately, package failure.
Unfortunately, there is no hard and fast rule for when to use a no-clean vs. a water soluble process. It really depends on the components you are placing and what your process needs are.
For example, if you have a board where excessive levels of oxidation or contamination are present, you may want to select a water soluble process for its ability to aggressively strip oxides.
Doug Dixon
Marketing
360-Biz
These component types have very low stand off heights and will be very difficult to clean underneath. Water soluble flux residues are normally corrosive and must be removed therefore I would not recommend using this option.
No clean would seem to be your preferred route providing you are satisfied that it can stay on the board.
Bryan Kerr
Principal Engineer - CMA Lab
BAE Systems
