Probe Card Manufacturer 'Sees the Unseen' With X-ray
Probe card manufacturer relies on mobile real-time x-ray inspection to verify the quality of its aligned probes at different stages along the assembly line.
Glenbrook Technologies
April 7, 2010 - Updated
April 5, 2010 - Originally Posted
Lead-free Assemblies Reworked with Leaded Solder
Can circuit board assemblies originally built using lead-free solder be reworked successfully using leaded solder? I realize the assemblies may not comply with RoHS requirements, but will they be as reliable? Do you have any general recommendations for changes to the rework process? Can you point to any industry specifications or documentation?
J. T.
This is a very common situation. The most important thing is that you MUST remove all traces of the old lead free solder. I would wick, re-tin with leaded solder and wick again. Once this is done then you can safely rework the area with leaded solder. Just be careful with all these heating operations and use a direct power soldering system, it will provide the maximum safety for your PCB assembly.
Master Bond
Creative-Electron
