Gold Embrittlement Solved!
We use robotic hot solder dip equipment for gold removal on SMT and through-hole components. Gold plating is fully removed and replaced with tin-lead solder.
March 12, 2010 - Updated
March 8, 2010 - Originally Posted
Polarity on LED SMT Components
Is there some standard that governs how polarity marks are used to denote orientation on a SMT LED component, PCB silkscreen, and on assembly drawings? Examples: Cathode or Anode in the case of an LED, Pin 1 on an IC, must the mark be visible from the top, etc. The following is included for background: I have been an SMT Manufacturing engineer for over 10 years. I program Pick & Place equipment along with SMT process debug. Within the past year I have been struggling with SMT LED orientations. I know how to read a polarity mark and look at a data sheet but I have been having issues with SMT LEDs. I started running a new assembly and it had two different color LEDs. The LED's were placed on the PCB in the same orientation according to the silkscreen mark on the PCB and the customer assembly drawing. I had not looked up the data sheet or looked at the assembly schematic. There were no questions with the assembly with regards to the LED orientation during visual and automated inspection until ICT says one LED is backwards on every PCB. I look at all the information and cannot understand why. Based on the data sheet for each LED, the polarity mark denoted the anode on one LED and the cathode on the other LED. Needless to say I was confused. Everything in my training and experience told me both LEDs were placed correctly, until I looked at the data sheets. Since the above described incident, there have been dozens of cases in which an LED had been placed backwards due to the polarity mark being misread. Historically, I have not had issues with SMT LED polarity. It seems as if LED polarity marks have become ambiguous and highly dependent on application and manufacturer during the past year. Can you offer assistance? Thanks for you time.
S. B.
Tradition for many years has made the cathode of diodes the feature to marked with a band or other indicator on the body of the part. LEDs have messed with tradition a bit partly because they are not always thought of as diodes any more but rather as a part with a more positive or plus (anode) contact and a more negative or minus (cathode) connection, like a polarized cap. And as you know, some caps mark the plus (+++++) like many tantalums and some mark the minus (-----) like many aluminum caps. Somehow we get caps right most of the time. Whether there is a standard for LEDs or not, if the LED manufactures do not follow it, it leaves it up to us (the contract manufacture) to get it right. I agree, LEDs are harder to know for sure, without opening the spec sheets and in some cases the schematics as well. It is up to the design engineer to make it clear, based on the LED's spec sheet, how to install the LED on the board based on some visual feature. If there is a question, it is up to the contract manufacture to get a good answer. Hopefully your customer is open to such communications on your part. Otherwise, you got a 50/50 chance of getting it right, and if you don't it's usually "your fault." Not the best answer, but I understand your issue.
Paul Austen
Senior Project Engineer
S.B., We are experiencing the same problem. A particular LED went obsolete and the replacement version is marked on the Anode instead of the Cathode (which is the standard marking). To add to the confusion, this only applies to one color on that supplier's datasheet. All the other LED colors have the polarity marking on the Cathode side. We are pushing design to not use that LED or add a note to the drawing that the part is marked on the Anode.
Brenda Schmidt, PCB assembly, USA
