November 22, 2017 - Updated January 17, 2010 - Originally Posted Concerns Using Aluminum Flux TankIf we use a flux tank with our wave soldering system that is constructed from aluminum, and we use water soluble flux, could the flux become contaminated by contact with the aluminum tank? S. S. |
If aluminum being used as a holding tank for flux is not a good idea. The tank will corrode from the acids and leach into the flux. This is especially true with the OA (organic acid) flux type you are using. Try to be 100% certain that the vessel is aluminum. Even some grades of stainless steel can pit on the surface with OA flux. This would give the visual effect as if the vessel is rusting. You can use warm water to clean this off and get your best confirmation or simply ask the supplier what the material is made of. If confirmation is made that the material is aluminum you will need to replace this. Consult with your supplier. One additional comment. The replacement material type will be dependent on the flux delivery system being used. If this is a pressurized vessel flux supply system, outlined as a vessel that uses compressed air or nitrogen to push the liquid flux out to the nozzle, the replacement vessel should be stainless steel with at least a 316 grade or better. Considering the flux is alcohol based, there are NFPA regulations that would dictate the use of an inert gas to pressurize a vessel when flammable materials are being used. I hope this information is helpful.
It is possible for contamination to occur, very much so. Aluminum is an active metal. It will react under both acidic and basic conditions, which would create aluminum ions solubilized into the flux solution, especially aqueous solutions. Most likely it would only be trace amounts, but finite and measurable. Alcohol based fluxes will be much less of a problem, but nonetheless the possibilities are still there. Based on my years of ink and coatings chemistry, aluminum vessels are a "no-no". My advice is either a plastic or glass lined container, or good old fashioned stainless steel. I'd be very happy to discuss this further with any/all interested parties.
Aluminium is chemically attacked by acid solutions and, as such, the water soluble flux is not compatible with this material. I would recommend a stainless steel tank for this application.
Using Aluminium flux tank is not the best idea especially if using a VOC Free flux as this will attack the tank. I would change to Stainless Steel for VOC Free. If using alcohol based Water Soluble then I would imagine this too could be an issue for Aluminium, not knowing the chemistries involved in your chosen flux I would prefer a welded Polyprop tank which is fairly cheap to construct to cope with ALL flux types.
