January 19, 2018 - Updated December 7, 2009 - Originally Posted SMT Component Lead OxidationHow do you suggest we remove oxidization from SMT component leads? The component leads are seriously oxidized due to long time storage. E. W. |
Since you had observed the oxidationin SMT Component you have to check the Moisture sensitive level of the component. The JDEC standard deeply explain the self life of the SMT components as well as the storage condition. If the component is to old (i.e the component stored for long time more than the self life), I would suggest not to use the component. The JDEC standard will help you more in this issue. The JDEC standard also explain how to increase the self life of the component.
Quality Engineer Matrix Telecom Solution P Ltd Sandip Thakor has 9 years of experience in electronics industry specializing in soldering technology. Thakor has experience in lead free installation, process optimization and developing quality standards.
This kind of depends on the termination style - leaded components can be pre-tinned using more active flux if necessary to break down the oxide layer. Chip components are trickier and replacement with new components should be considered. Prevention, of course, is the preferred route and if long term storage is likely then vacuum packing is a good option to prolong solderability shelf life.
I would suggest you contact your solder supplier. They can evaluate the solderability of your components and recommend a suitable flux.
The answer is to retin the leads to remove the oxidation and prepare the leads for the SMT operation. A wetting balance test can be performed to insure the leads meet solderability. The leads can be dipped in either lead free or leaded flowing solder pot.
As an internal fix, if it is not verydifficult, fluxing the components on a FR4 board and reflow them on a mild ovenprofile followed by a cleaning cycle should fix your problem.
After opening your vacuum package, store your components in a dry cabinet that uses nitrogen (very low flow) as inner atmosphere control. Nitrogen is dryer than air and has no oxygen. Good dry cabinets can reach very low oxygen levels inside it very fast after door openings. Residual oxygen level at low concentrations inside dry cabinets <100 PPM. So, no oxidation during components storage time.
Luiz Felipe Rodrigues, Air Liquide
