Probe Card Manufacturer 'Sees the Unseen' With X-ray
Probe card manufacturer relies on mobile real-time x-ray inspection to verify the quality of its aligned probes at different stages along the assembly line.
Glenbrook Technologies
December 9, 2009 - Updated
December 7, 2009 - Originally Posted
SN96 Solderability Issues
We have been hand soldering a connector using 63/37 solder. The connector has bright electrolytic tin as the finish. Recently we switched to SN96 and have been experiencing solderability issues. We sent samples to an independent test lab and had them run solderability testing using both 63/37 and SN96 with RMA flux. The 63/37 samples all passed and the SN96 all failed for de-wetting. As a side note the tin is plated on at 150 micro-inches thick and the connectors are approx. 2 months old. Can you shed any light on this problem?
B. R.
It is possible that you damaged the plating by operating your soldering stations at too high a soldering temperature. I would suggest evaluating a direct power soldering system operating at a lower tip temperature.
Master Bond
Creative-Electron
