Start Micro Dispensing Today
November 25, 2009 - Updated
November 23, 2009 - Originally Posted
Cause of Yellow/Brown Discoloration
What is possible cause of "yellow/brown" discoloration on a silver immersion circuit board assembly after the oven reflow process?
G. G.
The possible cause for yellow/brown discoloration are the flux viscosity and the reflow profile. You need to check the flux property like activation temp, viscosity, helide contains in the flux and temperature profile of soldering.Also check the amount of flux apply to the solder joints.
Sandip Thakor
Quality Engineer
Matrix Telecom Solution P Ltd
Sandip Thakor has 9 years of experience in electronics industry specializing in soldering technology. Thakor has experience in lead free installation, process optimization and developing quality standards.
Yellow / Brown color on silver is silver tarnish which is a combination of silver sulfide and silver oxide which occurs over time as silver is exposed to air. Heat accelerates silver tarnishing, so it is easily visible after the first reflow cycle. Unfortunately silver tarnish can cause solderability issues and subsequent reflow or wave soldering may be difficult.
Mike Scimeca
FCT Assembly
Touchless Solder Ball Removal
