Tech Paper - Essential Practices for Gold Mitigation of Electronic Components
This paper examines gold mitigation in electronic components, highlighting risks like cost volatility and environmental impact. Download this free tech paper.
Circuitnet
Circuitnet Media LLC
November 5, 2009 - Updated
November 2, 2009 - Originally Posted
What Is The Ideal HASL Thickness?
What is the ideal solder thickness for hot air solder leveled (HASL) lead free boards?
K. S. G.
The ideal thickness is to be thick enough for good solderability, yet thin (flat) enough for part placement. Because of the HASL process and surface tension of solder, smaller pads will have a greater amount of solder as compared to larger pads. Due to this and coupled with lead free HASL having an inter-metallic two times that of leaded HASL a minimum thickness is more crucial in the lead free process than the tin/lead process. It is difficult to spec in a certain thickness because of the process so we (Florida Cirtech) concentrate on a minimum thickness and not on a range. Our recommended minimum thickness would be 100 microinches as this should insure good solderability.
Mike Scimeca
FCT Assembly
Glenbrook Technologies
AI-Technology-Inc
