Plasma Etch
August 19, 2009 - Updated
August 17, 2009 - Originally Posted
Defective solder joints on HASL boards
What is possible cause of incomplete soldering after surface mount reflow? The bare circuit boards in question are hot air solder leveled. At the problem areas we notice a yellow stain on the hot air leveled surface of the PCB.
S. Q.
I would be very worried about either a surface contamination, or a change in surface tension at or around the area which exhibits the "yellow stain". Surface analysis with IR spectroscopy/microscope should give a definitive answer about any chemical changes which would affect the surface chemistry/physics. Hard to give a better answer with the limited info at hand.
Jim Williams
Chairman
Polyonics, Inc.
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
