June 8, 2009 - Updated June 8, 2009 - Originally Posted How to eliminate micro solder balls?We see significant numbers of micro solder balls after the solder wave process, especially on the SO14 and SOT23 SMD components. We use a water soluble flux and SNC100 solder alloy. Where should we look for solutions to reduce this solder ball problem? I. P. |
Check the solder resist cure as this will be the most significant factors. Take a ball under at least 60x magnification and carefully turn it over. If it is flat on the side sticking to the resist then it is due to poor cure OR insufficient hardener when the resist was applied.
Try a different flux. We have seen similar effects on such mundane things as barcode labels on the board surface.
