Plasma Etch
June 1, 2009 - Updated
June 1, 2009 - Originally Posted
Cause of Blow Holes During Wave Soldering
When wave soldering radial lead LED's, we are seeing blow holes. We have found that loosening the clinch applied by the placement machine resolves the blow hole issue. Any ideas why the tight clinch may be causing blow holes?
M. J.
Sounds to me that the tight clinch is acting as a dam preventing the flow of both the flux and the solder thru the vias. When you relax the clinch the materials flow smoothly eliminating the blow holes.
It is possible that if the clinch is too tight then the LED will form/sit over the top of the hole not allowing the hot gasses to escape from the flux and other items during wave soldering. Loosening the clinch a little may help in allowing the gasses to escape from the top of the joint.
Greg York
Technical Sales Manager
BLT Circuit Services Ltd
Most likely this is being cause by no escape route for the flux gas when the PCB enters the wave. If the clinch is too tight or there is no escape path the flux gas will escape out the bottomside barrel when the unit exits the wave. A tight clinch will pull the LED tight/flush to the board surface and not allow for the gas to escape leaving what looks like a blow hole. I hope this helps.
John Norton
Eastern Manager
Vitronics Soltec
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
