Simply Double the Production Volume
SEHO SelectLine features the award-winning Synchro and SmartSplit production modes that allow to halve cycle times in batch production and mixed operation. Find out more.
SEHO Systems GmbH
November 9, 2017 - Updated
May 26, 2009 - Originally Posted
Which term to use, PWB or PCB?
Is there any real difference between the terms Printed Wire Board (PWB) and Printed Circuit Board (PCB)? Which do you recommend we use for internal and external documents?
R. D.
This question has been discussed numerous times at IPC meetings and usually enables a fair amount of emotion.
All of the following are possible uses, depending on your age, geographic location (slang usage), and where/how you got your training. I'm sure there are more.
PB - printed board. the most generic term for a bare board
PWB - printed wiring board, one of the first uses when the issue was only a point to point connection.
PCB - printed circuit board, where the width, side to side and multi-layer relationship(spacing) of conductor runs has or is designed to have a specific effect on circuit operation other than just a point to point connection. Circuit impedance is a primary issue. In approximately 1999 the IPC Technical Activities Executive Committee made a mandate to only use the term PCB for all new document development because more often than not the printed circuitry design will have an impact on function.
PWA - printed wire assembly - older use
PCA - printed circuit assembly - logical to use with the 1999 change to PCB.
PCBA - printed circuit board assembly - multiple requests/comments (strong push) from users and technical committees in Asia and Europe to use this as the preferred term.
Embedded active or passive components opens up a whole new range of possibilities as well.
While it would be good to have a single term (or pair of terms for bare boards and assemblies) reality is that there are many IPC documents of various age using different terms and many more book and magazine article authors, conference lecturers, etc., that pretty much use whatever term they are most comfortable with.
If preparing a document; it would be appropriate to use a term that most of the expected users would understand. In the world of electronics technology, it would seem that most users should be able to understand the content when any of these terms are used.
Jack Crawford
Director - Certification & Assembly Technology
IPC
Mr. Crawford is Director of Certification and Assembly Technology for IPC. He is technical liaison to the IPC committees that maintain critical industry standards and has presented numerous papers internationally.
Great question. IPC-T-50H, has a definition for each of these terms, Printed Circuit Board, provides both point-to-point connections and printed components in a predetermined arrangement on a common base. Printed Wiring Board, provides point-to-point connections but not printed components in a predetermined arrangement on a common base. There is a difference between the two, but I would say the industry has used the term interchangeably throughout the history of electronic manufacturing. Left to my devices all raw boards coming from the board shops should be called Printed Wiring Boards.
Most of the industry uses PCB. So that would be the term for me.
No Real difference. PCB is the more modern term.
Gary Goldberg
President and CEO
PROMATION, Inc.
Mr Goldberg has practical experience in production line layout, process flow and cycle rate analysis. He knows how to avoid bottle necks and most related PCB or pallet handling questions.
It is same, PCB is used more than PWB.
Scott Chen, Excellence PCB Technology Co.,Ltd
I started in the 70s calling them Printed Wire Boards and Printed Wire Assemblies as still prefer those terms. A Printed Circuit is just that, a circuit that is printed to the board with printed resistors, traces printed specifically to provide deliberate capacitive or inductive effects, or other "printed" components as in a Hybrid.
To say that "printed circuitry design will have an impact on function" negates the fact that even if all components are connected by discrete wires, those wires still impart LCR characteristics to the circuit function.
Personally I think we as an industry just got lazy and instead of continuously correcting the commonly misapplied term "Printed Circuit" we just gave up and accepted it.
Terminology is only useful if it has specific meaning and we now have ambiguous terms that don't specify exactly what we are talking about.
David Mason
Great answer and history in the article and great responses, as well. As circuit board manufacturing consists of two very distinct stages-fabrication and assembly--it would seem that at least two terms are required. For the bare board, which is the fabrication result, the commonly used PCB seems most appropriate as the process involves printing and (etching) to realize the copper circuit layout.
PCBA, which is the end product of assembly, provides the needed distinction and accurately denotes that the final product is the assembled printed circuit board. This being said, most seasoned engineers are able to make the necessary determinations, regardless of what terms are used. However, for those new to the industry, having so many terms can be confusing.
Michael Cooke, First Page Sage
Plasma Clean, Etch and RIE in One Machine
The PE-100 convertible allows you to perform plasma cleaning, isotropic etching and reactive ion etching(RIE) in the same system!
Plasma Etch
Creative-Electron
