Creative-Electron
Creative Electron
Circuitnet
Circuitnet Advertising Delivers Results!
Introduce your technology, new products or services in our daily e-mail newsletter & website to see how a digital advertising campaign can deliver results. Reach over 200,000 professionals.
Circuitnet LLC
March 9, 2009 - Updated
March 9, 2009 - Originally Posted
Recommended Rework Dwell Times
I need advice on rework dwell time/soldering time. Can a dwell time that lasts too long cause open traces in leaded rework? What is the recommended dwell time in rework process?
A. Y.
From the question, the subject seems to be for a hot air rework station where there is temperature control. If you are using a hot air rework station and the reflow process can be observed, we recommend no more than a few seconds of dwell after all the solder has liquefied and stopped moving. This is all the time it takes to be sure the solder has fully wetted out as far as it can. Extra heating time has no advantage. If the process is hidden, up to 30 seconds of dwell may be necessary to ensure all the solder has reflowed and wetted out at the coldest spots in thearea being reworked.
John Vivari
Nordson EFD
Dwell time on a reworked component is usually based directly on the dwell time targeted during the production process (your reflow oven). You can refer to the component manufacturer's reflow guidelines and see if any specific notes are given regarding rework. Although lead free solders require hotter rework profiles, the dwell times are still in the 60 to 150 second range for most components. The dwell time ensures that all solder joints have sufficient time above liquidus to create an acceptable solder joint. This joint will have a thin layer of intermetallic compounds. Excessive dwell time will create a thicker layer of IMC, which is more brittle, and will lead to a less reliable joint as the layer grows. I believe open traces could be the result of an improper component removal process, residual solder removal (site preparation) or some other manual process that is not thermally well controlled. Here small layer separation is possible, which can lead to solder wetting to areas away from the pad itself.
Neil O'Brien
Sales Director
Finetech
When hand soldering utilizing Sn/Pb solder, the maximum dwell time at any thru-hole lead should be 20 seconds. A much shorter period of time at each lead is preferred if IPC-A-610D acceptable results are achieved. The solder iron tip temperature should be controlled to a max. temp. of around 300 C. As with any rework process, there is potential for trace damage if time and temperature limits are exceeded.
Joe Karcewski
Product Manager
APS-Novastar, LLC
Joe Karcewski has been a Process Engineer for 16 years in the industry. He is a certified IPC-A-610 trainer and is presently working at APS-Novastar as a Product Manager for Soldering Systems including Selective Soldering systems.
Viscom
Latest 3D AOI System from Viscom
iS6059 PCB Inspection Plus. Its new and faster sensor technology, data processing and analysis functions all stand for the best 3D AOI performance that meets the highest requirements.
Viscom
