Sponsor |
Ask the Experts |
March 4, 2009 - Updated
March 2, 2009 - Originally Posted
Measuring component height after reflow
I have an SMT component that has a height of 8 mm with a stencil thickness of 5mm. We are using lead free solder paste, the pad size is 11"x.054".
Is there a method for determining the overall height of the component on the board after reflow?
C.S.
Expert Panel Responses |
I would suggest using a VPI-1000 from Easybraid. Once the assembly is reflowed you can simply measure the height.
Sponsor |
Master Bond
