Ask the Experts |
February 2, 2009 - Updated
February 1, 2009 - Originally Posted
High Tg PCB requirement
Do we need to use a High Tg PCB material for a double sided PCB that is 62 mils thick if the PCB will only see one solder reflow step?
D.Q.
Expert Panel Responses |
Are you trying to process lead free metal? Do you have small packages on the board. Lifting pads could be of concern if processing at 850 degrees F. I personally prefer to use the higher Tg material in all my designs and have never got in trouble with processing both lead free or good old leaded solder.
Take a look at VT-47 Datasheet for Lead Free Assemblies.
James Mahoney
Applications Project Manager
Quick Turn Flex Circuits LLC
James Mahoney is a Technical Operations Manager with a 20 year track record in managing new product introduction. He is a skilled leader, motivator and problem solver with a strong background in Product Knowledge and Engineering Management.
Sponsor |
