January 19, 2009 - Updated January 19, 2009 - Originally Posted DI Resistivity for Wafer Dicing and CleaningWhat should DI water resistivity be for wafer dicing and cleaning? What might be the effect of lower DI resistivity on the performance of the wafer? N.P. |
I did some research found out that "For front end applications like this usually companies are working with a conductivity level of maximum 1 uS (minimum of 1 MegOhm). The rinsing performance itself will be not significantly influenced by a higher conductivity or lower resistivity but the ions might cause some reliability and functionality issues on the chip."
The current specification for DI at the dicing process is 0.5 Mohms to 2 Mohms. We try to stay close to 1 Mohm. The theory is that the higher the DI resistance the less capability to properly ground the saw blade and therefore a higher build up of charges at the spinning blade that can lead to ESD events. A too lower resistance is also and indicator of impurities on the water that can cause corrosion on metal pads on top of the wafer.
Ivan Lara, International Rectifier, Mexico
By using CO2 reionized DI water, it will prevent any static related risks and also avoid any contaminants since CO2 will leave no residue after drying.
Fei Xu, Liquid Intelligent Control System, Inc., USA
