Plasma Etch
January 19, 2009 - Updated
January 19, 2009 - Originally Posted
Reflow Solder Process Issue
We have a "solder robbing" issue with our reflow process. We feel it is related to the temperature uniformity of the reflow oven? Are there other conditions that would create this problem?
Q.N.
To minimize the occurrences of solder robbing during reflow, the profile should be modified to have a longer low temperature soak time to drive off the lower boiling point volatiles. Additionally, the boards could be reflowed in an inert atmosphere to preventany additional oxidation. The nitrogen level should be between 20 to 200 ppm of oxygen.
Terry Jeglum
President/CEO
Why do you believe it is related to temperature uniformity? Typical drivers for solder robbing is overprinting or slump of the solder paste. Is this under a BGA?
Dr. Craig D. Hillman
CEO & Managing Partner
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
