December 22, 2008 - Updated December 21, 2008 - Originally Posted Procedure for Baking Flexible CircuitsWhat is the proper procedure for baking flexible circuits where we need to bake the flex at 125 C for 6 hours? Does the oven need to be preheated before we begin this process? M. K. |
What's the end users process? Soldering the flex (lead free or not), Surface finishing, plasma processing, drying a high layer count rigid flex preventing shorts at electrical? Typical Bake for soldering flex circuits and rigid flex 12 layer and below: 2 hours min @ 250 degrees F Solder within 2-3 hours after bake. No need for 6 hours if the fabricated has laminated at the correct temp and time. Yes oven should be convection with air flow and at temperature.
This is a very good question and most people have different views but I am an old flexible printed circuit board guy both polyester and kapton material sets. The idea is to drive water absorption out of materials and it should a slow process of allowing the pcb to ramp to temperature and cool to ambient or close to it over 8 to 12 hours and the temperature should be 105 degrees C. Naturally Kapton material sets can handle higher temperatures than polyester. KAPTON can handle 125 degrees C but the idea is to drive water out of the material set slowly and effectively.
