September 27, 2017 - Updated December 14, 2008 - Originally Posted IPA Cleaning PrecautionsWhat safety precautions need to be taken when cleaning boards or electronic components with of IPA (isopropyl alcohol or isopropanol) cleaning solutions? A.R. |
A) Precautions for Safe Handling and Use Steps If Matl Released/Spill: Wear proper protective clothing. Eliminate all sources of ignition. Stop leak if can be done at no risk. Use water spray to reduce vapaors. Absorb with sand or other non-combustible absorbent and place in container for disposal. Flush area w/water. Waste Disposal Method: Dispose of in accordance with applicable local, state and federal regulations. EPA/RCRA hazardous waste number d001 (ignitable waste) may apply to unused/uncontaminated product. Precautions-Handling/Storing: Keep container tightly closed. Store in a cool, dry, well-ventilated, flammable liquid storage area. Do not store near oxidizing materials. Other Precautions: Bond & Ground Containers When Transferring Liquid. B) Control Measures Respiratory Protection: Respiratory protection required if airborne concentration exceeds TLV. At concentrations above 1000 ppm, a chemical respirator with organic vapor cartridge is recommended. Above this level, SCBA is recommended. Use IAW 29 CFR 1910.134. Ventilation: Use general or local exhaust ventilation to meet TLV requirements. Protective Gloves: Neoprene Gloves. Eye Protection: Chemical Splash Goggles and/or Faceshield Other Protective Equipment: Uniform, apron. DLA-HMIS: eye wash station & safety shower. Work Hygienic Practices: Wash hands before eating, drinking, smoking, or using toilet facilities. Wash contaminated clothing before reuse.
I assume you are speaking of cleaning PCBs with a brush and a small bottle of alcohol, or sometimes in an open top cleaning machine of some sort. In that case, you will find there are at three main problems with alcohol: First, alcohol is "hygroscopic." This means it absorbs water from the air, which dilutes the alcohol and weakens its ability to clean. Alcohol also is often diluted commercially by 20% or more, to keep the price down. This dramatically reduces its cleaning strength. Using weak, water-filled alcohol is a bad process that can lead to labor-intensive cleaning. Make sure you specify the purest, most water-free alcohol you can find. Secondly, alcohol is a very weak cleaner. It has a low Kb value and it saturates with flux residues at 2% by weight. So it takes a lot of solvent to successfully clean a typical circuit board. It's not the cost of the solvent that is the issue -- it's the cost of time lost cleaning inefficiently. So here are some steps you can take that will help cleaning work better:
The best advice I can offer is "don't use IPA". There are many other chemistries available that clean better, are much safer and environmentally friendly. First of all, IPA is a volatile organic compound (VOC) and is therefore a smog producer. Many areas have regulations prohibiting or limiting the use of VOCs and regulations are frequently changing so the appropriate regulating agencies should be consulted on an ongoing basis especially before incorporating an IPA cleaning process. IPA has a low flashpoint and warrants all surrounding electrical equipment and outlets to be explosion / fire proof. Appropriate equipment to provide vapor containment or safe exhaust should also be employed. At Smart Sonic, we make aqueous-based stencil cleaners. Over the years, we have replaced two IPA stencil cleaners that exploded. Many people feel the IPA machines are safe because the machines are pneumatic and the electrical controls are remotely located to prevent an ignition spark. However, the first IPA machine we replaced experienced an ignition spark due to a static discharge as the machine and operator were not properly grounded. The other machine experienced a mechanical spark because the stencil dislodged from its fixture and the revolving stainless steel spray nozzles hit against the metal stencil. Boom! Manufacturers of equipment using low flashpoint solvents such as IPA incorporate a fire extinguishing system within the machine. That alone should tell you something. These fire extinguishing systems usually work well - if they survive the explosion. On top of all of this, IPA requires personal protective equipment including: skin protection, eye & face protection, and respiratory protection, special storage, special transportation, and the empty containers are considered hazardous by RCRA. Your insurance carrier for fire and workers comp should also be advised of the use of flammable liquids.
Firstly, IPA is a flammable solvent so you will have to ensure the area where the substrates are to be cleaned is safe. Also, if using an ultrasonic tank or any other electrical equipment, to assist the cleaning process, it should be flame proofed. As IPA is a volatile solvent there are workplace exposure limits for the chemical. These can be found on most safety data sheets. IPA should be used in a well-ventilated/extraction equipped area. A lot of useful information regarding safe use can be found on any standard health and safety data sheet for IPA.
I recommend following the standard precautions for IPA. It is flammable, so keep heat and spark sources away from it. It dries the skin and is moderately hazardous to your body. IPA is a carrier which helps allow dissolved substances to penetrate into the body. Gloves, goggles, etc. should be worn. Do not breathe the fumes. Good ventillation is recommended. As far as the board and components go, it will wet and penetrate everywhere. The board should be rinsed and dried thoroughly when finished. When drying, the heat source chosen should be safe.
IPA is a very stale cleaning agent. For personnel, eye protection should be worn at all times. IPA can cause dry skin where ever it comes in contact with the operator's skin. If the operator is sensitive to IPA, protective gloves can be worn. As always, have a working, inspected fire extinguisher available. IPA has a relatively low flash point and can easily cause a fire. Finally, make sure that IPA is chemically compatible with all other chemicals used in the assembly process. Chemical reactions can occur with certain substances. Check your MSDS for full compatibility and safety protocols.
