September 29, 2008 - Updated September 29, 2008 - Originally Posted Frequency range for ultrasonic cleaningWhat is the frequency range that is used when ultrasonic cleaning a pcb that has a crystal or oscillator? A. N. |
Ultrasonic cleaning is specifically addressed in the J-STD-001D document. You'll find that ultrasonic cleaning is not recommended for a populated circuit board. However, if you do choose to use ultrasonic cleaning, check with the component manufacturer to establish if:
While the ultrasonic frequency is an important consideration, research studies have shown the Power Density and ultrasonic exposure time (cycle time) may be of equal or greater importance. There are several published articles and a copy of the IPC-7526 on the subject available for download at: SmartSonic, click on the "Recommended Reading" button. The IPC-7526, "Stencil and Misprinted Board Cleaning Handbook" summarizes these cleaning parameters on Page 6, Section 4.3 as follows:
In almost all cases, 20 kHz is used. A sweep frequency ensures that the actually frequency moves +/- 5 kHz. Although ultrasonic technology is effective in post-reflow and misprint defluxing, it is not commonly used as fear of damage discourages most assemblers.
