Ask the Experts |
July 13, 2008 - Updated
July 13, 2008 - Originally Posted
Effect on Eutectic Melting point for a multiple alloy board
How do multiple lead-free alloys, combined with a tin-lead Solder Paste, lead-free components, and tin-lead components effect the Eutectic melting points for a solder joint?
As an example: Let's say I am starting with SnPb solder paste and add a few SnPb components with an ENIG (Immersion Gold over Electroless Nickel) circuit card and I add a SnAgCu (Tin, Silver, Copper) alloy BGA. Next, I add some SOICs, QFPs, and PLCCs where the specs identify Tin (lead-free) leads.
This brings ENIG, SnPb, SnAgCu, and possibly 100% Sn all together in one spot, with the common denominator being the SnPb solder paste.
R. S.
Expert Panel Responses |
The simplest answer is that you get a mess.
Consider this; if you take equal amounts of 10/90 tin-lead solder and eutectic 63/37 solder and melt them you end up with 37.5/63.5 solder. The tin-lead binary phase diagram tells us that the liquidus of this composition is 247°C instead of the 183°C we would expect with eutectic solder or the 299°C for 10/90.
Add some SAC with silver, copper and more tin and the resultant mess makes an indistinguishable porridge that defies classification. Given that the eutectic for tin –silver is over 200°C and the addition of more tin to SAC raises the liquidus beyond 217°C, one could assume that you would need higher temperatures to get this porridge to melt and form a joint. But the actual temperature is almost impossible to predict.
The bottom line is don't mix because you'll never know for sure what is going on and even worse – if you get it to make an acceptable looking joint there is no knowledge about reliability.
Fred Dimock
Manager, Process Technology
BTU International
