May 27, 2008 - Updated May 27, 2008 - Originally Posted Changing Conformal Coating MaterialWe are considering changing over our pcb conformal coating process from a silicone based material to a urethane based material. Are there any concerns regarding the current equipment other than obviously replacing the material delivery lines and cleaning/replacing the spray nozzles? M.J. |
There are several considerations when making a switch like this. First, sounds like you are taking the correct precautions for preventing cross contamination. Depending on your process, you may have overspray on the conveyors. Make sure to clean all parts that come in contact witht the board. Next, you have to consider the material rheology and your coating method. There are many methods of coating: air atomized spray, airless atomized spray, ultrasonic atomization, film coating, jetting, and needle dispensing. If the material that you are switching to has a similar viscosity, you may be in luck. If the material viscosity is very different, you will probably have to adjust your settings or use a differnt size nozzle. Worst case, your current method may not be suitable to the new material and you will haveto switch methods.If that is the case, you should first go back to the equipment manufacturer and provide thefluid part number and manufacturer to see ifthey have recommendations. In somecases, the supplier of the fluid will have hardware recommendationsfor your specificequipment. If the material you are changing to contains solvents or solvents that are different than the material you were using, you should check to make sure your equipment meets NFPA codes for fire / explosion prevention and make sure that you comply with EPA, OSHA, state, and local requirements for ventilation and emissions.
Director of Application Engineering Asymtek Mr. Lewis worked for The Aerospace Corporation for 6 years before joining Asymtek in 1993. He holds multiple patents in dispensing technology for electronics assembly and packaging. He has a Master's Degree in Mechanical Engineering from University of Missouri-Rolla.
NOTE: Mr. Lewis is no longer working at Asymtek. Changing from a silicone to a urethane conformal coating should not cause too many problems if you are careful not to contaminate the polyurethane with any remaining silicone. The main differences between the products are related to their chemistries and cured film properties. The main thing you need to check is the viscosities of the two materials to make sure they are similar. If this is the case then spraying should be fine, providing you have the correct set up. Silicone contamination can be difficult to remove and so it is important to thoroughly clean any non-replaceable parts with a solvent that is compatible with the silicone. Following this you should flush the spray equipment with the solvent used to dilute the urethane material before filling with the new coating. Silicone contamination can cause issues with wetting and overall coating appearance therefore it is best to run a couple of spray tests first on scrap material prior to carrying out any production work.
The following steps should be performed when changing from a silicone conformal coating to another material type such as a urethane:
President Ultrasonic Systems, Inc. Mr. Erickson is co-founder of Ultrasonic Systems, Inc. a technology leader in ultrasonic spray technology. Hi is holder of several patents related to ultrasonic spray technology. His roles include product development, technology application, sales and marketing.
