Plasma Etch
April 14, 2008 - Updated
April 14, 2008 - Originally Posted
Determining Current Carrying Capacity
How do you determine the current carrying capacity of PCB traces and vias? What tools and formulas are used to make the calculation?
M. N.
Check out IPC-2152.
Dr. Craig D. Hillman
CEO & Managing Partner
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
