Start Micro Dispensing Today
November 3, 2010 - Updated
January 6, 2008 - Originally Posted
Glass Transition and Decompsition Temps for Lead Free
What is the correct glass transition temperature (Tg) and decomposition temperature (Td) for the lead free process?
R. M.
The glass transition temperature should be determined using the Thermo-Mechanical Analysis (TMA) method as per IPC-TM-650, 2.4.24C[3]. The TMA method is preferred over the other two methods sometimes used to determine the glass transition temperature, DSC[4] and DMA[5], because the thermal expansion of the PCB is a critical parameter, which is given by TMA as a function of temperature. For PCBs subject to soldering processes using the more elevated soldering temperatures required for lead-free solders, specifying a glass transition temperature, Tg, of 140C will not be adequate for PCBs thicker than about 50 mils. Furthermore, for thicker PCBs, it is recommended that a minimum decomposition temperature, Td, determined as per IPC-TM-650, 2.4.24.6[6] as well as a maximum thermal expansion coefficient in the PCB thickness direction, CTE(z), determined as per IPC-TM-650, 2.4.41[7] be specified. CTE(z) values should be given separately for temperatures below Tg and above Tg; however, frequently the thermal expansion, TE in %, is lumped together from 50 to 260C or even 50 to 288C. Typically, the decomposition temperature is given as Td(5%) to a 5% weight loss; the decomposition temperature, Td(2%), to a 2% weight loss, has been found a very good indicator, but is not as yet widely available. Frequently, the time to delamination, either T-288 or T-260, are specified either in addition to Td or instead of it. The T-288 delamination time provides a more appropriate level of performance given the process temperature required for LF-soldering. The delamination time is sometimes combined with the requirement that that temperature needs to be survived for 4 to 5 excursions. The easiest way to specify the three properties critical for the survival of the PCB and the PTH/via interconnect structure - Tg, Td, thermal expansion (TE) - is by specifying a minimum Soldering Temperature Impact Index, STII, which is defined as STII = Tg/2 + Td/2 - (TE%(50 to 260C) x 10). For PCBs with thicknesses of 0.06 inches (1.5 mm) or more, an STII-value of 215 or larger is recommended. However, the STII-concept is not widely used as yet. Thanks to Werner Engelmaierfor all the above information. I had this data since fall of 2006.
Terry Jeglum
President/CEO
Requirements are primarily driven by peak temperature, which is driven by component and board size / thickness / complexity. With small components and a small board, Tg between 130 and 150C can be sufficient. Larger components and a larger board tend to need Tg closer to 170C to 180C.
Dr. Craig D. Hillman
CEO & Managing Partner
Tg and Td are important material properties, as they influence the resin system in organic substrates. In lead-free processing,
  • Peak assembly temperatures can reach a point where resin decomposition begins.
  • Higher temperatures result in increased thermal expansion and moisture absorption and stress on plated holes
  • Vapor pressure of the absorbed moisture at lead-free assembly temperatures can lead to blistering/delamination
Glass Transition Temperature (Tg): The temperature at which the resin system changes from a rigid or hard material to a soft or rubber like material. Issue: Several properties change as the Tg is exceeded, including the rate at which a material expands with temperature. Temperatures above Tg results in,
  • Higher moisture permeability
  • Higher CTE
  • Reduction in modulus
Decomposition Temperature (Td): The temperature at which material weight changes by 5%. This parameter determines the thermal survivability of the resin material. Issue: Resin decomposition can result in adhesion loss and delamination. The chemical bonds break upon exceeding Td resulting in permanent degradation and damage to the material. Preferred attributes for Pb-free Assembly: Decomposition Temperature (Td) >340C For standard thickness printed wiring boards (1.6mm) a material with a glass transition temperature of greater than 170C is recommended as a minimum requirement
Bjorn Dahle
inspīre solutions LLC
Touchless Solder Ball Removal
