August 9, 2017 - Updated October 8, 2007 - Originally Posted Method for cleaning boards after misprintWhat is the correct process for cleaning bare boards after solder paste mis-print?
E. R. |
The best method for cleaning mis-printed boards is to immerse the boards in some sort of an ultrasonic dip-tank and clean them with a nonflammable solvent. Such machines are made by JNJ Corp., SmartSonic, and others. Lockheed Martin even made one, a number of years ago, called a JetClean machine. Shop around; you can get excellent values on these machines. Do not use alcohol as the solvent in these machines; alcohol is a weak cleaner that quickly saturates with paste and will stop cleaning quickly, so you're constantly draining and cleaning the machine. A better choice is a nonflammable, water-based solvent such as MicroCare's "BGA Stencil Cleaner" which has been engineered specifically for this application. It's much stronger than alcohol, lower aroma than alcohol, lower VOC content, nonflammable and in general provides a much better and faster cleaning result. Cleaning misprints manually, which many companies do, is sub-optimal. Solder paste gets into vias, apertures and/or on the ends of the boards, and unless the techs are extremely conscientious, some residues always remain. Most companies then blow-dry the board with compressed air, which often blows microscopic bits of oil onto the board. This cleaning process also wastes a lot of labor, ties up inventory and consumes quantities of solvents and paper wipes. Overall, this is just a bad idea. One other thought - if you're getting a lot of misprints (more than 2-3 per hour at normal production speeds) then the problem isn't the cleaning, it's the root cause of what's causing the misprints. More often than not, it's ineffective cleaning from the stencil wiping paper. Better paper will give better wiping, which can dramatically reduce misprints and defects at functional test. One such stencil wiping paper, the MicroWipe FP paper from MicroCare, has been proven to boost yield as much as 82%, generating huge savings in rework, throughput and improved yields.
Misprinted circuit boards should have excess solder paste manually removed from the surface with a suitable cleaner recommended by the solder paste supplier and a lint free wipe. These boards should then be cleaned in an automated cleaner to further remove any residual solder paste in vias, through hole barrels or lodged along the edge of the solder mask. It might also be a good idea to mark the edge of a misprinted boards with a Sharpe as an identifying mark. This way, boards processed in this manner are easily recognized at the end of the production line should further disposition be necessary.
Regioanl Sales Manager ASM Assemby Systems Mike Burgess is the ASM Assembly Systems PSP Regional Sales Manager, who has numerous years of experience in the electronics industry as a user and supplier. He is responsible for stencils, screens, tooling, chemistries, fabric rolls, and stencil coatings.
Manual cleaning of the misprinted board through either wiping or scrapping results in entrapment of the solder balls in the vias or other board apertures. To ensure proper, reproducible cleaning results and last but not least complete removal of all solder paste from the misprinted boards, we highly recommend using a automated cleaning process supported by either an ultrasonic or a spray-in-air agitation using an alternative cleaning agent to IPA. The limited solvency of IPA on the flux residues was overcame with alternative aqueous based cleaning agents that do not only ensure the proper removal of the solder paste but also provide excellent compatibility with board finishing ranging from immersion silver to OSPs and are in full compliance with the environmental regulations. Cleaning trials performed at independent technical centers that have real cleaning replicating capability would certainly be the most effective way to pin point which cleaning agent and equipment would be the most appropriate for your current application.
This is a good opportunity to let everyone know that the IPC has recently published the Stencil and Misprinted Board Cleaning Handbook (IPC-7526). This and other related articles are available on the Smartsonic web site as a free download.
Hand wiping is not effective for removing uncured solder paste due to solder ball smearing over the surface of the circuit assembly. Tiny solder balls may end up in via's or other small spaces and lead to shorts. Solder paste and particulate removal is often more difficult than dissolving uncured flux residue. The most reliable removal method for is a process that integrates mechanical and chemical driving forces. Solder balls are held in place by the flux composition. Developing an integrated cleaning process, releases the solder balls and allows removal during the wash and rinse cycles. For additional information, IPC-7526 Stencil and Misprinted Board Cleaning Handbook may be downloaded free of charge.
CTO Kyzen Corp. Mr. Bixenman is the CTO for Kyzen Corp. Kyzen Corp. is a leading provider of engineered cleaning fluids for high technology manufacturing environments.
The best procedure for cleaning solder misprints is to;
You must not wipe the Misprinted board, instead, immerse the whole PCB in a Solvent cleaner and we use compressed air through diffusers in our systems to blow off the powder. This method completely removes everything after a couple of minutes and then PCB can be removed and dried without any rinsing required. System is low cost and requires no electrics so no flammability issues
