Plasma Etch
August 5, 2007 - Updated
August 5, 2007 - Originally Posted
Changing PCB finish from FR2 OSP to FR4 HASL-Lead Free
We have changed PCB finish from FR2 OSP to FR4 HASL-LEAD FREE and have encountered pinholes in the PCB solder joints. We have tried different wave settings but are still unable to solve this problem. We did not have this problem when using FR2 OSP. Is there a way to keep these pin holes from occurring?
R.B.
Pin holes as well as blow holes are usually a sign of excess moisture in the PCB or poor PTH plating. The moisture in the PCB heats up over the wave and ruptures the PTH plating, then the steam escapes through the bottom of the fillet causing a pin hole or the larger blow hole. Bottom line is that you have boards from your vendor that are of poor quality. The only thing that may help you is to bake the boards at 120C for 4-6 hours. If it is just too much moisture this will fix the problem but if the plating in the PTH is bad it may not make a difference. Either way your board vendor needs to work on their process..
Greg Hueste
Senior Applications Engineer
Speedline Technologies
Vision-Engineering
Are you sitting comfortably?
Vision Engineering
