Sponsor |
Sponsor |
Plasma Etch
Ask the Experts |
July 16, 2007 - Updated
July 24, 2007 - Originally Posted
Acceptable "reject rate" for hand assembly
What is an What is an acceptable "reject rate" for a total hand assembly, through hole operation line. I have established a less than .10% of all total hand placed through hole components for our load room.
We are a small low volume, high mix firm, using through hole boards, wave soldered. Is this a reasonable level to expect from our process?
Robert Bartolotta
Expert Panel Responses |
Typical first pass yield on hand assembly is 5000 ppm.
Dr. Craig D. Hillman
CEO & Managing Partner
Sponsor |
Are you sitting comfortably?
Vision Engineering
