Start Micro Dispensing Today
September 18, 2006 - Updated
Removing oxidation from partially assembled boards
Is there a way to remove the tarnish formed on white tin finished PCB's? We perform SMT assembly on some low-volume boards then store them for up to three months before applying through-hole components to order. We have seen a few orders with poor solderability due to oxidation on the white tin finish. I know how our board supplier can refinish bare boards but how can I save these partially assembled items?
Jay Bosserman
Try increasing solder pot temperature and going to a more aggressive flux formulation (maybe moving from a no-clean to an aqueous). This might be an easier approach than attempting some type of rework process.
Dr. Craig D. Hillman
CEO & Managing Partner
You may have to use a higher solids flux that is more active to remove the oxides. This could also require that you clean the boards after wavesoldering.
Greg Hueste
Senior Applications Engineer
Speedline Technologies
Tarnishing is caused by contact with the air that we breathe, or more specially oxygen. Although I am not sure of a simple way to remove it after it has occurred, I do know how to prevent it. If you put the assemblies into sealed bags and fill the bags with nitrogen prior to sealing that should stop the tarnish from forming in the first place. Use a standard ESD safe bag that can be heat sealed. There are off the shelf inexpensive systems for doing this, contact your local supplies distributor. When you are ready to assemble the board simply remove the bag.
Ken Bliss
President & CEO - Retired
Bliss Industries, Inc.
Touchless Solder Ball Removal
