Plasma Etch
High-Density Rigid PCB Boards
Is My PCB Wash Concentration in Check
Evaluating wash concentration levels through varying testing methods can potentially save process time, reduce overall process costs, and increase cleaning efficacy on PBCs. Read more.
April 23, 2022 - Updated
Cleaning an assembled board with IPA
If the PCBA is cleaned with IPA to remove the no-clean flux residue, will the IPA residue on the PCBA cause a potential electrochemical migration problem over time?
If not, what kind of test is recommended to confirm? SIR test?
S.L. Lee
The short answer is, almost certainly yes, the residues will cause a problem. But the detailed answer is much more complex. Let's take a look at the question, step by step: 1. Most people don't know that pure IPA alcohol leaves almost no residues. By itself, high-quality IPA is a very clean material and if properly packaged, handled and used it can be expected to produce no more than 200-400 ppm of residues, and almost all of those residues are actually from the packaging. The bad news is that very, very few people buy high quality IPA. IPA is considered a commodity, so everybody wants a low price, so they buy the cheapest IPA on the market. These materials often are highly diluted (usually with water of uncertain origins) to lower the selling price. Products like these will not deliver high quality, reliable cleaning. 2. The migration to lead-free materials has made the cleaning situation worse, not better. IPA saturates at about 2% by weight, so if you had 100 kilos of exhausted, dirty IPA you would only be carrying about 2 kilos of flux residues. That's not very much. In addition, IPA has a fairly low "K-B value" of about 50 (sources differ on the exact rating) which is the measure of "cleaning horsepower." Lead-free materials typically require higher temperatures, longer process times and more active fluxes. These all lead to difficult cleaning situations, requiring higher Kb values, and old-fashioned IPA simply lacks the cleaning strength to handle these contaminates. 3. Most engineers try to select the best solvent but allow their operators to use the solvent in a dirty "Menda" style bottle, often with a dirty acid brush (see photo). So even if the solvent was high-purity material, it will be contaminated and recontaminated before it ever gets on to the PCBA. The best answer is to replace the IPA with a more modern, stronger, faster-drying solvent that delivers more cleaning power to the PCBA. I recommend the HFC-based cleaners or the HFE-based cleaners marketed by TechSpray, Chemtronics, Micro Care and others. In general, only those solvents will have the "muscle" to remove the lead-free no-clean residues in a quick and efficient manner. In addition, I would recommend an improved solvent delivery system, such as those produced by Miller-Stephenson or Micro Care, to reduce solvent consumption, eliminate waste and improve the cleaning process. These tools allow operators to wet the substrate, scrub the substrate, and then rinse the contamination from the board quickly, and without a lot of wasted solvent. Remember this: if you can't rinse, you can't clean. As for the testing, your best results will be obtained from 28-day SIR testing. This is a long and expensive process, so my strong suggestion would be to develop the best process you can and then merely validate the process with standardized SIR testing. Old-style "Omega meter" testing, which uses a DI-water bath and sensors to meaure halites in the water, is less precise but a whole lot cheaper and faster; it may be sufficient for some applications.
Mike Jones
Vice President
Micro Care
Different no-clean solder pastes produce different residues with different characteristics. You are taking the right approach in checking the compatibility. To be sure the IPA will clean the residue, an SIR test is a good method. You should also be sure to use the same reflow profile for the SIR boards as will be used in the production. You are also going to want to make sure the cleaning method is enough to remove the residues. A simple wipe or "squirt" of IPA is unlikely to remove no-clean residues. If you are using a cleaning system you may also want to look into cleaning chemistries designed to clean no-clean residues. There are several companies that manufacture both solvent based and aqueous compatible chemistries that will have a much better chance of success than an IPA wash.
Dr. Brian Toleno
Application Engineering
Henkel Electronics
With a no-clean residue, it is best to either leave the residue uncleaned or insure that the residue is removed completely. Without knowing the exact composition of the flux, it is tough to predict if an IPA cleaning process will completely remove the residue. I would suggest cleaning the residues with your typical IPA process and performing an ionic cleanliness test on the cleaned assemblies to assure yourself that the board is free from any ionic material. If the boards are completely cleaned, IPA should completely evaporate over time and no "residue" would be present. IPA does not leave a residue unless there was some sort of solid material dissolved in it that is not removed from the assembly when the IPA evaporates.
Brian Smith
DEK International
Cleaning no-clean is not normally recommended but there are times it is necessary. IPA is not a good cleaner. A cleaner that is compatible with the no-clean should be used. Most cleaner/ solvent suppliers will have cross reference of recommended products to clean a specific no-clean. Since IPA is not a good cleaner and depending on the no-clean you could strip an encapsulating part of the flux off and leave active material exposed. This then would reduce the SIR values and possibly lead to dendrite growth. The best test to run would be SIR and electro migration to verify your process.
Karl Seelig
Deck Street Consultants
IPA is not capable of removing "no-clean" flux residues properly. Using IPA will result in leaving either partially cleaned (white powder) or untouched flux residues. Furthermore, should the same IPA solution be used for board rinsing purposes, the customer will experience long term climatic reliability issues. Those problems usually occur when IPA is loaded up with contaminants that could redeposit on the board surface. To reduce this redeposition phenomenon, the operator will have to make use of fresh IPA to rinse off the boards. Proper cleaning of the board can then be measured by using a ionic contamination tester. To further assess the cleanliness level of the assemblies we recommend the following test procedures: Flux Test, Visual Microscopic Inspection, Ionic Chromatography, Impedance Spectroscopy, SEM (Scanning Electron Microscope), Core Test.
Umut Tosun
Zestron America
Wave Soldering Processes Rethought
As a pioneer in the development of automated soldering technologies, SEHO is setting global standards today more than ever with outstanding features. Find out more.
SEHO Systems GmbH
