May 7, 2007 - Updated July 4, 2007 - Originally Posted Wave Solder fluxingWhat is the maximum preheat temperature for alcohol based flux used in wave process? We are finding dirty sticky material on the bottom of the boards after the wave, can you offer a suggestion to this problem? M.K. |
Two reasons for the preheat are to remove carrier solvent, and reduce thermal shock as the PCB hits the wave. IPA boils at 82°C, but volatilizes well before this. Wave temperature is around 250°C, but it's not a good thing to subject components to this temperature for a long period! Of course, another reason is to prepare (clean) the PCB to facilitate solder wetting. The Arrhenius equation militates towards high temperature, but preservation of activator militates against high temperature. Against this background, and experience, we recommend from 80 - 100°C topside, depending on conveyor speed. But, as you can see, it's a question of balance. And there are other factors. For example. a large heavy PCB will demand higher temperature as it will behave as a heat sink. Post soldering residue may reflect poor (insufficient) preheat that leaves unreacted activator. But another source is simply over application of flux. Increased wave activity can help as it washes activator/residue from the PCB.
This may have more to do with the choice of flux than any particular wave soldering parameter. When you identify a dirty, sticky material on the bottom of boards after the wave, this is usually simply the residue that is left behind from some flux types. All no-clean fluxes are not created equally, and some no-clean fluxes include a small proportion of rosin (the sticky stuff) in the formula to assist with the heat stability of the flux as the board reaches wave soldering temperatures. (Among liquid flux activators, rosin is among the best at retaining some level of chemical activity at the elevated temperatures during contact with the wave.) It is highly likely that the sticky material on your boards is just the rosin portion of the residue that remains after soldering. It is almost certainly not a reliability issue but if your customer is wanting to see this remedied, you can either switch to a non-rosin (or possibly a lower-rosin) liquid flux or potentially clean the boards after soldering. If you choose the path of a rosin-free no-clean flux, note that the lack of rosin may impact solderability performance and this may not be advised if this is a lead-free assembly. Leaded wave soldering can more easily be accomplished with a rosin-free no-clean flux than a lead-free application can.
As often as not, the sticky material is excess flux residues from the soldering process. The best option is to remove these residues before they cause problems. Aqueous cleaning systems, benchtop cleaning with a brush, or vapor degreasing with a nonflammable solvent are your best options, depending upon the equipment you have and the volume of boards expected. Here at Micro Care, our most popular recommendation is to clean with our Flux Remover C, a nonflammable, fast-drying solvent that's safe for people, the planet and the budget.
