June 11, 2007 - Updated
Hand soldering process
Why is a short dwell time important for hand soldering? Why not set the iron temperature to 500 deg. F (or less!) and just heat the part longer? If the part receives the same amount of heat, are there any consequences besides labor time loss?
S.D.
A short dwell time reduces the amount of heat transferred up the lead and into the body of the component. The component load on the soldering iron is a much smaller load then the thermal load of the entire printed circuit board so a temperature of 600 – 700 F is recommended for typical soldering operations. Soldering at 500 will cause the part to overheat and create cold solder joints on the circuit board.
